Results 1 to 8 of 8
  1. #1
    Join Date
    Jun 2013
    Posts
    4
    Location
    Minnesota
    Mower
    Scotts
    Starter locks up on flywheel!
    Okay,I have a scotts(by john deere)riding lawn mower.It was sitting for about 5 years,and I decided to try to get it going again.I bought a new spark plug and made sure it had spark,and changed the oil.My battery was dead of course and my ignition is shot so i jumpstarted the STARTER with our car.when i jumped it the starter engaged the flywheel but the starter always locks up when the cylinder starts to compress.It turns just fine without the spark plug. I adjusted the valve lash 3 times.And im getting 12v to the starter.I am now taking apart the starter to clean.But i dont know what the problem is.Please Help!
  2.
  3. #2
    Join Date
    Mar 2012
    Posts
    7,295
    Location
    Wisconsin
    Mower
    Toro
    Re: Starter locks up on flywheel!
    If the battery is bad, jump starting it with the battery installed could be the problem. The dead battery is sucking the juice from the jumper battery. Also check the battery ground on the chassis. If it is not making a good connection the engine will acted just like you described.
    This is only my opinion, and many will say it ain't worth a darn, as I'm only a retired grease monkey instructor and not a professional mechanic. Use what I post at your own risk as you know teachers only know book knowledge.
  4. #3
    Join Date
    Jun 2013
    Posts
    4
    Location
    Minnesota
    Mower
    Scotts
    Quote Originally Posted by Rivets View Post
    Yes i thought of that,thats why I am jumping right to the starter not the battery.So it woudnt matter if the battery is dead or not.....right?
  5. #4
    1,000 Post Club
    Briana's Avatar
    Join Date
    Jul 2010
    Posts
    1,550
    Location
    California
    Mower
    Looking to Buy :)
    Welcome to LawnWorld!
    I moved your thread to the Small Engine & Mower Repair forum.
  6. #5
    Join Date
    Jun 2013
    Posts
    4
    Location
    Minnesota
    Mower
    Scotts
    Quote Originally Posted by Briana View Post
    Thanks
  7. #6
    Join Date
    Mar 2012
    Posts
    7,295
    Location
    Wisconsin
    Mower
    Toro
    Checking the valve clearance would be the next step in the process to solve you problem.
  8. #7
    reynoldston's Avatar
    Join Date
    May 2011
    Posts
    5,646
    Location
    Marion,NY
    Mower
    Ferris, John Deere, Wheel Horse, Toro,
    Is the starter gear hanging up onto the shaft? Try just a little light oil between the gear and shaft. Also why are you bypassing the starter solenoid? If you are using a good pair of battery jumper cables you don't need to bypass anything but if you are using junk jumper cables you will accomplish nothing.
  9. #8
    Join Date
    Jun 2013
    Posts
    4
    Location
    Minnesota
    Mower
    Scotts
    (reynoldston;111036]Is the starter gear hanging up onto the shaft? Try just a little light oil between the gear and shaft. Also why are you bypassing the starter solenoid? If you are using a good pair of battery jumper cables you don't need to bypass anything but if you are using junk jumper cables you will accomplish nothing.)
    I would do that but mice chewed up half the wiring.I adjusted the valves again and now the flywheel will turn but not very fast at all even though Im getting 13v to the starter.I was able to start it with starting fluid but will not stay running.One time I saw a flame come out from the carb.Could it be a blown head gasket?Why is the flywheel turning so slow?I cleaned the carb.Thanks for the replies,keep em comin
Similar Threads
  1. Replies: 3
    Last Post: 10-26-2017, 12:04 PM
  2. Repairs Lawn Boy drive wheel locks up
    By Pike in forum Lawn Boy Forum
    Last Post: 04-14-2013, 12:35 PM
  3. Engine 'locks up' and won't turn over (crank)
    By Georgia Boy in forum Small Engine & Mower Repair
    Last Post: 06-28-2012, 09:36 PM
  4. starter, how to reverse direction on a craftsman lawn mower starter
    By gemayna in forum Small Engine & Mower Repair
    Last Post: 04-19-2012, 06:45 PM
  5. Replies: 5
    Last Post: 04-08-2012, 08:50 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
