Results 1 to 6 of 6
  1. #1
    Join Date
    May 2013
    Posts
    Location
    Texas
    Mower
    Gravely
    Tecumseh Carburetor Flooding
    I have a murray push mower with a Tecumseh series 6 carburetor. I have complete disassembled the carb, put new seals and gaskets. Carb continues to flood/drain fuel out. I hooked up the fuel without the bowl on it, and the fuel would stop when I lifted the float up. Float checks out ok, and needle seats fine. Any other suggestions?
  2.
  3. #2
    Join Date
    May 2013
    Posts
    Location
    Texas
    Mower
    Gravely
    Re: Tecumseh Carburetor Flooding
    Did some looking on-line, the carburetor is a model 632670.
  4. #3
    1,000 Post Club
    EngineMan's Avatar
    Join Date
    Jun 2012
    Posts
    1,985
    Location
    South Wales UK
    Mower
    No mowers
    It can only be something to do with float, needle or seat. or has you say "it works o.k without the bowl on" so check when you refit it.
    WORN NEEDLE AND SEAT
    This is another area that can wear rapidly from dirt or foreign matter in the fuel system. This condition creates a poor seal at the seat area causing the carburetor to flood or the engine to run rich. This can also cause the needle to stick in the seat which will stop the flow of fuel.
    "Information/Knowledge not shared will be lost for ever, I will give freely any information that will help you out, you don't have to take it, that is up to you...! and the word "thank you" will not cost you anything, so be nice sometimes and use it"
  5. #4
    Join Date
    May 2013
    Posts
    Location
    Texas
    Mower
    Gravely
    With the bowl on, I can turn it upside down and try to blow through the fuel inlet, and none comes through, rightside up air flows through fine. I read somewhere that if the vent is clogged, it won't allow the float to rise. Does anyone know where the vent is on this carb?
  6. #5
    1,000 Post Club
    EngineMan's Avatar
    Join Date
    Jun 2012
    Posts
    1,985
    Location
    South Wales UK
    Mower
    No mowers
    Maybe this may help you.......
    Attached Images Attached Images
  7. #6
    Join Date
    Oct 2010
    Posts
    243
    Location
    Mulvane Kansas
    Mower
    Quote Originally Posted by gregyore View Post
    When you had the carb apart did you shake the float and make sure it didn't have any gas in it? Even though you properly tested the needle and seat, the float won't float well and close the seat if its holding fluid.
Similar Threads
  1. Tecumseh carburetor
    By dnoonkeste in forum Tecumseh Engine Forum
    Last Post: 08-26-2013, 04:32 PM
  2. Engine Tecumseh Carburetor linkage
    By dnoonkeste in forum Craftsman Forum
    Last Post: 03-28-2013, 12:42 PM
  3. Tecumseh LMT carburetor (632015) Needle seat.
    By silver1 in forum Tecumseh Engine Forum
    Last Post: 03-27-2013, 11:09 AM
  4. Tecumseh LMT carburetor rebuild today.
    Last Post: 02-08-2013, 05:15 PM
  5. Tecumseh Carburetor
    Last Post: 08-26-2011, 07:26 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
