Results 1 to 5 of 5
  1. #1
    Join Date
    May 2013
    Posts
    Location
    Kentucky
    Mower
    John Deere LA 150, blades stopped
    While mowing the blades stopped, I turned the PTO off and back on again with no results. Now when the PTO is turned on it makes an audible click and the pulley under the engine jerks, but does not turn. Engine runs great, and the belts seems to be fine. The safety switch for engine cut off under the seat seems to be working normally. Could the clutch under the engine be damaged or just worn out? The mower is about 7 years old, until now the only part that has been replaced is the starter solenoid and battery.
  2.
  3. #2
    Join Date
    Oct 2010
    Posts
    503
    Location
    Kentucky
    Mower
    1993 John Deere F725, 2000 John Deere 335, 2010 John Deere 3038E
    Re: John Deere LA 150, blades stopped
    If you are hearing a click, then the clutch is functioning. You say the belt is fine, but have you checked the tension on that belt? If that is the original belt, or even only two or three years old, then it could be stretched to the point where the tensioner pulley can no longer keep it tight. Also, check the tensioner spring, it could be fatigued and no longer able to keep proper tension on the belt. Look at the clutch pulley itself when the PTO is engaged, make a mark of some sort on it so you can see if the PTO pulley is actually rotating when it is engaged. Being seven years old, it is entirely possible the clutch needs to be adjusted. The friction material may have worn down. There should be three bolts around the perimeter of the clutch, probably facing down, that are used to set the gap between the friction material and the pulley. I'm not sure what that gap should be when the clutch is disengaged.
  4. #3
    Join Date
    Oct 2010
    Posts
    503
    Location
    Kentucky
    Mower
    It looks like the air gap should be no more than .025". Here is a link that maybe will help you out. I'm thinking step 4 is what you'll be interested in reading.
    Fixing Electric Clutches
  5. #4
    Join Date
    Oct 2010
    Posts
    243
    Location
    Mulvane Kansas
    Mower
    Quote Originally Posted by mullins87 View Post
    I was repairing a rider last week for a customer who complained that when he went to engage the blades the mower had a clicking sound and the blades would not turn. I flipped it on its side and removed about 50 pounds of 3 and 4 inch thick mud from under the deck. Once the deck was cleared the blades had room to turn and the problem was solved. Another good reason not to mow when the ground is wet.
  6. #5
    Join Date
    Oct 2010
    Posts
    503
    Location
    Kentucky
    Mower
    Quote Originally Posted by Ifixdit View Post
    Wow, I'm surprised the engine didn't stall when the blades were engaged.....but yet another possibility.
Similar Threads
  1. John Deere LA 145 slowed down then stopped
    By zachcoss in forum Small Engine & Mower Repair
    Last Post: 06-07-2013, 12:50 AM
  2. Repairs John Deere pop sound and stopped
    By Sean_Rey in forum John Deere Forum
    Last Post: 08-27-2012, 09:02 AM
  3. John Deere Z225 runs sluggishly when blades are engaged
    By rhschmi in forum Small Engine & Mower Repair
    Last Post: 07-27-2012, 10:18 PM
  4. Blades will not turn on John Deere STX38
    By jsten in forum Small Engine & Mower Repair
    Last Post: 07-02-2012, 05:38 PM
  5. John Deere L120 stopped cutting -now won't start
    By mjwillyone in forum John Deere Forum
    Last Post: 08-08-2011, 09:26 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
