Power Kraft 18/42
weedman
It starts . I cant get it to move.. the brake is off, the hydro is engaged. When I let out the clutch ,even a little it seems like its still has the brake still on and it shuts off the motor. I don't know what next to try . HELP
Check the following. 1. Pull the motion relief valve and see if you can roll the unit. If it won't roll your brake may be frozen. 2. Take the deck off and check the motion drive belt. It may be pinched and not moving freely.
Briana
Welcome to LawnWorld!
I moved your thread to the Small Engine & Mower Repair forum. :smile:
