Results 1 to 3 of 3
  1. #1
    Join Date
    May 2013
    Posts
    Location
    United States
    Mower
    Power Kraft 18/42
    Power Kraft 18/42
    It starts . I cant get it to move.. the brake is off, the hydro is engaged. When I let out the clutch ,even a little it seems like its still has the brake still on and it shuts off the motor. I don't know what next to try . HELP
  2.
  3. #2
    Join Date
    Mar 2012
    Posts
    7,292
    Location
    Wisconsin
    Mower
    Toro
    Re: Power Kraft 18/42
    Check the following. 1. Pull the motion relief valve and see if you can roll the unit. If it won't roll your brake may be frozen. 2. Take the deck off and check the motion drive belt. It may be pinched and not moving freely.
    This is only my opinion, and many will say it ain't worth a darn, as I'm only a retired grease monkey instructor and not a professional mechanic. Use what I post at your own risk as you know teachers only know book knowledge.
  4. #3
    1,000 Post Club
    Briana's Avatar
    Join Date
    Jul 2010
    Posts
    1,550
    Location
    California
    Mower
    Looking to Buy :)
    Welcome to LawnWorld!
    I moved your thread to the Small Engine & Mower Repair forum.
Similar Threads
  1. Kraft Pro 18.5 dogs and dies in nm
    By emeraldgirl in forum Small Engine & Mower Repair
    Last Post: 10-07-2012, 02:20 PM
  2. KRAFT PRO 18.5/46 dogs out and dies in nm
    By emeraldgirl in forum Mower & Equipment Operation
    Last Post: 09-17-2012, 09:38 PM
  3. Kraft Pro 18.5 dogs and dies in nm
    Last Post: 09-14-2012, 10:53 PM
  4. Replies: 1
    Last Post: 07-26-2012, 09:47 AM
  5. Powr kraft???
    By domes in forum Mower & Equipment Operation
    Last Post: 04-07-2012, 08:46 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
