Rickshawky
- May 6, 2013
- Threads
- 4
- 12
Full video drive belt replacement on Troy-Bilt Pony
BTW - If any of you are having the problem of your mower won't go up hill or won't move at all in lower gears and or only moves unless you 'pop' the clutch. AT 3:43 in this video...just under that silver pulley is a threaded rod, That is the adjustment to fix that, you'll want to move it toward the front of the mower. It's not easy to move the arm it sits on but with a 'long' bar and being 'very' careful what you are prying against - you can get it to move.
