Results 1 to 6 of 6
  1. #1
    Join Date
    Apr 2013
    Posts
    Location
    Arizona
    Mower
    Honda Harmony 215SX
    I recently purchased a used Honda lawnmower, Harmony 215SX, from a friend at work for $50. My fiancee said that was too much for a used lawnmower but it looks in good shape and is rear wheel drive with a 2 speed trans. Along with the mower, my friend also gave me the service manual, new airfilter, and the 2 carburetor gaskets I might need to do the carb clean it required since it had been sitting for over a year. I cleaned the carb, changed the spark plug and engine oil, retorqued the blade bolts and other minor tune up stuff. It fired up first pull but then wouldn't run off of choke so I looked online for advice and thanks to help from this forum I figured out that I hadn't cleaned the slow speed jet sufficiently so I went back, did that plus a couple of other adjustments and it runs pretty good now. I still feel like the rpm difference between the fast and slow throttle settings should be greater, however when I adjust the throttle cable for higher rpm in fast setting the governer will flutter the rpm between stalling and high rpm and occasionally stall out like it isn't getting enough fuel. If I disconnect the governor linkage though and hold the Carb butterfly wide open I get the rpm I would expect for wide open so I am not sure if I actually need a bigger main jet or not. Sure seems weird that the difference between slow and fast is only a couple thousand revs but it mows the grass great so I am thinking that I should just stop tinkering. That's my story, any advice or comments of the positive nature are most welcome. Thanks!
  2.
  3. #2
    bwdbrn1's Avatar
    Join Date
    Nov 2011
    Posts
    381
    Location
    IL/MI
    Mower
    Honda, Vintage Jacobsen
    Re: Honda Harmony 215SX
    Does yours have two screws under the carb body? They are part of the control plate. One of those adjusts the choke activation, the other works on the high rpm settings. If you have access to a tach, use it to check the actual RPMs. Idle should be 2100 rpm +or- 150 rpm and high speed should be 3,150 to 3,300 rpm.
  4. #3
    1,000 Post Club
    robert@honda's Avatar
    Join Date
    Nov 2011
    Posts
    1,789
    Location
    Georgia
    Mower
    Here are the engine speed adjustment procedures from the shop manual.
    Use a tachometer; if you try and do it "by ear" you'll either get it too slow (poor cut quality) or too fast (shorten the engine life, danger of fragmented blade).
    Robert@Honda
    Social Media Consigliere
    Caveat: I work for Honda, but the preceding is my opinion alone.
  5. #4
    5,000 Post Club
    lawn mower fanatic's Avatar
    Join Date
    Jun 2012
    Posts
    6,759
    Location
    Pennsylvania
    Mower
    Two Honda HRX217HYA's and an HRR216TDA
    I moved your thread to the Honda Forum.
    2013 4x6 custom utility trailer
    Honda HRX217(3)HYA mower
    Honda HRX217(5)HYA mower
    Honda HRR216TDA mower
    Echo SRM-225 trimmer
    Echo GT-2100 trimmer
    Echo PB-770T backpack blower
    Echo PB-255LN handheld blower
    Echo PE-225 edger
    Craftsman 24" 179cc dual-stage snow blower
    Black and Decker 22" electric hedge trimmer
  6. #5
    Join Date
    Apr 2013
    Posts
    228
    Location
    Pennsylvania
    Mower
    old Snapper V212P, Snapper P217017BVE hi-vac, Lawn Boy silver series 10202, Honda hr194
    I'd say you got a great deal on that mower. I've been looking at them on CL in my area and havn't been able to find one for less than $100.
  7. #6
    bwdbrn1's Avatar
    Join Date
    Nov 2011
    Posts
    381
    Location
    IL/MI
    Mower
    I'd say you got a good deal. Tell your fiancee I just sold one for $225.00.
Similar Threads
  1. Repairs Honda Harmony HRB 215
    By kri223 in forum Honda Forum
    Last Post: 09-04-2016, 01:21 AM
  2. Honda Harmony II HRR 216 question
    By pjc in forum Small Engine & Mower Repair
    Last Post: 06-17-2014, 05:32 AM
  3. Repairs honda harmony rider
    By langer53 in forum Honda Forum
    Last Post: 06-24-2013, 10:44 AM
  4. Honda Harmony 11 HRR216
    By kdino in forum Small Engine & Mower Repair
    Last Post: 08-07-2012, 03:49 PM
  5. Honda Harmony 215 SX
    By gmcnitt in forum Honda Forum
    Last Post: 06-20-2012, 09:52 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
