Results 1 to 2 of 2
  1. #1
    Join Date
    Nov 2010
    Posts
    Location
    Utah
    Mower
    Craftsman DLT2000 Transmission won't engage
    Hello,
    I have a Craftsman DLT2000 riding mower/tractor, it has an automatic transmission, 20 hp Kohler engine, and a 48" mower deck. It work fine yesterday, but today it will not go forward or backwards. When either the forward or the reverse pedal is pushed it just growls. I have checked the emergency brake and I have verified the belts are all in the correct place (I replaced them at the start of the mowing season this year so they are fairly new).
    The mower deck will engage and the blades spin.
    But the tractor can't be pushed forwards or backwards. It is clear the transmission is not letting the back wheels rotate.
    The belt from the engine to the rear transmission is engaged and spinning.
    Any ideas on how I should start trouble shooting this issue?
    Thank you in advance.
    John Harvey
  2.
  3. #2
    Join Date
    Nov 2010
    Posts
    Location
    Utah
    Mower
    Re: Craftsman DLT2000 Transmission won't engage
    I got it fixed. The parking brake mechanism wasn't quite completely dis-engaging. I used a stronger spring and all is now fine. Also I found out that the pedal mechanism needs to be overhauled, so i fixed one problem and found another.
Similar Threads
  1. Old craftsman
    By buntrock in forum Craftsman Forum
    Last Post: 03-16-2012, 09:28 PM
  2. Replace JD LA145 Transmission or buy JD 314 for same price?
    By jewalker33 in forum John Deere Forum
    Last Post: 09-21-2010, 10:46 PM
  3. Huskie Transmission LT4200
    By dennisB in forum Transmissions & Transaxles
    Last Post: 05-07-2010, 10:50 PM
  4. Grasshopper Transmission Fluid
    By klm in forum Transmissions & Transaxles
    Last Post: 05-06-2010, 08:19 AM
  5. Huskiee 42inch Transmission?
    By dennisB in forum Mower & Equipment Operation
    Last Post: 05-05-2010, 08:39 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
