Results 1 to 3 of 3
  1. #1
    rejaak's Avatar
    Join Date
    Sep 2012
    Posts
    Location
    Indiana
    Mower
    LawnBoy
    179cc Chonda engine air gap
    ok, i have a craftsman 24" snowblower (a 2010 model i believe) with a 179cc Chinese motor, engine designation 265/SU-11. i'm attempting to replace the flywheel and install a stator as it currently doesn't have a pigtail to run electrics. i'm expecting the parts today. the problem is: i measured the air gap and it was .030 which i thought was kinda large. i downloaded a shop manual from MTD for the 179cc motor and they state the air gap is to be between .008-.016. there are so many iterations of this motor that at times it's confusing. it runs ok and starts easily although it seems to run lean. i'm just hoping the new flywheel and stator will bolt on. from lurking certain forums, most say the parts are interchangable. be that as it may, does anyone have knowledge of this motor and its pecularities? thanks for any help on this.
    1997 Lawn Boy Gold series Model 10523
    2006 Lawn Boy Model 10685
  2.
  3. #2
    rejaak's Avatar
    Join Date
    Sep 2012
    Posts
    Location
    Indiana
    Mower
    LawnBoy
    Re: 179cc Chonda engine air gap
    hi again. this is a follow up in case anyone needs the info. i got my parts and installed..bada bing!, i have voltage coming out my pigtail. so if anyone is interested, here's the lowdown: my engine is a 265/SU-11 which has NO stator and the flywheel has NO magnets. i ordered a flywheel (part #951-10805) for a 365-SUB and a stator (part #951-10719). the stator does not have the 2 mounting bolts so you would have to scrounge for them. luckily i had some in my collection. i also set the air gap to .016 and it runs fine. now to get a 12v dc regulator to run my LED running lights and i'll be in business for next winter.
  4. #3
    Join Date
    Aug 2011
    Posts
    856
    Location
    Kansas
    Mower
    Toro self propelled troybilt bronco
    Thanks. I do not need the info, but someone will.
Similar Threads
  1. 7 hp Briggs gap settings
    By bakerg in forum Briggs & Stratton Forum
    Last Post: 01-03-2013, 09:59 AM
  2. Engine Temp of Air Cooled Engines in Winter
    By SeniorCitizen in forum Mower & Equipment Operation
    Last Post: 07-20-2012, 12:31 PM
  3. Spark plug gap goes to zero in minutes
    By drumgod828 in forum Lawn Boy Forum
    Last Post: 06-08-2012, 02:33 PM
  4. coil gap for a fs-45 weedwhacker
    By cybsterman in forum Stihl Forum
    Last Post: 05-04-2012, 04:56 PM
  5. why the big gap in deck sizes
    By LandN in forum Mower & Equipment Operation
    Last Post: 02-27-2011, 12:34 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
