Results 1 to 3 of 3
  1. #1
    Join Date
    Apr 2013
    Question PTO clutch problem
    Hi. I am new to the forum, but have a serious question about the electric PTO clutch on my Dad's Cub Cadet 1045. The wire harness going into the clutch has rubbed & broken off too close to the clutch to be able to splice a new wire. It is a Werner Electric # 521979. Is there any other way to repair other than replacing the whole clutch & pulley assembly?
  3. #2
    Join Date
    May 2010
    Kansas, Butler county, Just east of DooDah
    Re: PTO clutch problem
    Hello & WELCOME to these Forums...
    There will be a plastic block at the end of the wires at the clutch, You may be able to carve enough of it away to solder new leads to that clutch... It is where Werner attached their leads to the coil winding. Be careful and you should be able to do it...
    Otherwise its a major job to replace only the coil.
    Replacing the complete assembly will set you back around $150 +(that clutch is used in a lot of CubCadet & MTD models)... so I would take the shot at attaching new leads... KennyV
  4. #3
    5,000 Post Club
    lawn mower fanatic's Avatar
    Join Date
    Jun 2012
    Two Honda HRX217HYA's and an HRR216TDA
    I moved your thread to the Small Engine & Mower Repair Forum.
    2013 4x6 custom utility trailer
    Honda HRX217(3)HYA mower
    Honda HRX217(5)HYA mower
    Honda HRR216TDA mower
    Echo SRM-225 trimmer
    Echo GT-2100 trimmer
    Echo PB-770T backpack blower
    Echo PB-255LN handheld blower
    Echo PE-225 edger
    Craftsman 24" 179cc dual-stage snow blower
    Black and Decker 22" electric hedge trimmer
Similar Threads
  1. electric pto clutch.
    By wesk in forum Small Engine & Mower Repair
    Last Post: 04-21-2016, 02:44 PM
  2. pto clutch removal
    By dam1914 in forum John Deere Forum
    Last Post: 05-14-2012, 01:21 AM
  3. Blades No PTO Clutch
    By Hopper1 in forum Grasshopper Forum
    Last Post: 06-11-2011, 08:23 AM
  4. PTO clutch
    By skidder in forum Small Engine & Mower Repair
    Last Post: 07-31-2010, 07:54 AM
  5. Cub Cadet i1050 - PTO Clutch Engagement Problem
    By Canada_CT230 in forum Small Engine & Mower Repair
    Last Post: 05-12-2010, 10:56 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
