Results 1 to 9 of 9
  1. #1
    Join Date
    Apr 2013
    Posts
    4
    Location
    Alabama
    Mower
    Primer bulb not priming enough
    I replaced the primer bulb on my 6.5 hp B&S but still have to pump 40 or more times or pour gas in carb to start, Can hear a little suction noise and see a little fuel in base of bulb housing but not enough to start . Runs fine once running. Bulb seems to be properly seated? Help please.
  2.
  3. #2
    1,000 Post Club
    pugaltitude's Avatar
    Join Date
    Jan 2012
    Posts
    1,141
    Location
    Scotland
    Mower
    Lots
    Re: Primer bulb not priming enough
    Quote Originally Posted by wch View Post
    Did you take the air filter housing off to do the primer or install it with the filter housing on the engine?
    If you took it off then the gasket between the housing and carb is not sealing the channel in the airfilter housing to the primer hole on the carb.
    All you are doing is priming but no fuel going to carb for start up.
    Add another gasket to it which depending on the engine is part number 795629 from Briggs.
    The "best" engine you will ever own!
    Briggs & Stratton MST.
  4. #3
    Join Date
    Apr 2013
    Posts
    4
    Location
    Alabama
    Mower
    I removed the housing. I'll try the gasket. Thanks!
  5. #4
    1,000 Post Club
    Briana's Avatar
    Join Date
    Jul 2010
    Posts
    1,550
    Location
    California
    Mower
    Looking to Buy :)
    Hello wch! Welcome to LawnWorld.com.
    I moved your thread to the Small Engine & Mower forum.
    Good luck with your repair!
    Briana
    LawnWorld.com
    Administrator
  6. #5
    txzrider's Avatar
    Join Date
    Apr 2012
    Posts
    389
    Location
    Texas
    Mower
    Country Clipper
    by the way the double gasket trick fixed mine last year.
    Country Clipper Jazzee 2038BSG-SR110 , Snapper FRP 216012, Cyclone Rake, retired Snapper Zrider yz1333.
  7. #6
    bwdbrn1's Avatar
    Join Date
    Nov 2011
    Posts
    381
    Location
    IL/MI
    Mower
    Honda, Vintage Jacobsen
    Just went through the same thing with a Briggs. I was told to check the air box for cracks because it may have been over tightened causing it to warp, thus not sealing against the gasket and carb. I think a previous owner may have done just that because the metal threaded piece that the outer cover screws into was partially pulled out of the plastic case. I did the double gasket trick too, and made sure not to do a Magilla Gorilla tightening job when putting it on.
  8. #7
    Join Date
    Apr 2013
    Posts
    4
    Location
    Alabama
    Mower
    Thanks to all replies. I'm trying to locate a new gasket now. Will try your suggestions.
  9. #8
    Join Date
    Dec 2012
    Posts
    234
    Location
    Indiana
    Mower
    IHC Cub cadet
    The air cleaner base on those engines being plastic, warp. As suggested, Double gasket is the trick and should solve your problem.
  10. #9
    Join Date
    Apr 2013
    Posts
    4
    Location
    Alabama
    Mower
    Replaced gasket. Seems to be working well now . Thanks to all responders.
Similar Threads
  1. primer bulb
    By JDDK in forum Bolens Forum
    Last Post: 03-21-2013, 05:36 PM
  2. primer bulb
    By laserzack in forum Mower & Equipment Operation
    Last Post: 08-02-2012, 05:04 PM
  3. primer bulb
    By laserzack in forum Small Engine & Mower Repair
    Last Post: 08-02-2012, 03:38 PM
  4. Primer Bulb Problem
    By simonds in forum Small Engine & Mower Repair
    Last Post: 10-20-2011, 05:46 AM
  5. Tecumseh primer bulb
    By Derek in forum Tecumseh Engine Forum
    Last Post: 09-30-2011, 04:42 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
