Results 1 to 7 of 7
  1. #1
    Join Date
    Aug 2011
    Posts
    Location
    Indiana
    Mower
    d170
    oil filter for john deere d170
    will it hurt anything to use an automotive oil filter and a cheaper oil than briggs oil? it costs more to change the mower oil than it does my car!
  2.
  3. #2
    PJ's Avatar
    Join Date
    Mar 2012
    Posts
    176
    Location
    South Africa
    Mower
    Quote Originally Posted by swalt View Post
    Clean filtered oil and oil presure main principle achive that and your engine will last oil quality is important
    Sent from my iPad using LMF
  4. #3
    Join Date
    May 2010
    Posts
    5,447
    Location
    Kansas, Butler county, Just east of DooDah
    Mower
    CTL
    Re: oil filter for john deere d170
    You can get High quality oil filters at most auto parts stores, many will be as good as OR Better than the ones 'labeled' mower filters...
    Oil will be easy to find a Much better oil even synthetic for Less than the labeled oils. KennyV
  5. #4
    Join Date
    May 2010
    Posts
    557
    Location
    Minnesota
    Mower
    country clipper (jazee)
    HI Do a oil filter number cross over and see what other brands will fix you mower like Kenney said there are a lot of very good filter that will work a lot cheaper for your mower
  6. #5
    1,000 Post Club
    pugaltitude's Avatar
    Join Date
    Jan 2012
    Posts
    1,141
    Location
    Scotland
    Mower
    Lots
    Are you buying the john deere packaged oil filter?
    They can be expensive due to the packaging.
    The "best" engine you will ever own!
    Briggs & Stratton MST.
  7. #6
    PJ's Avatar
    Join Date
    Mar 2012
    Posts
    176
    Location
    South Africa
    Mower
    Quote Originally Posted by KennyV View Post
    This is personal choice even with your car the choice is yours as I said clean filtered oil oil pressure and good quality oil and you will be OK
  8. #7
    Join Date
    Aug 2011
    Posts
    855
    Location
    Kansas
    Mower
    Toro self propelled troybilt bronco
    Four cycle engines do not hold the interest of the owner near as much as two cycle stuff does. You will find many Stihl owners that will run nothing but Stihl oil but not many who will run Briggs oil in a Briggs product. The small engine filters are expensive. But most folks only use them once a year. But you are right, cost as much or more than the oil change in your car if you go with the engine makers branded oil and filter.
Similar Threads
  1. Repairs John Deere D170 won't start
    By COMPUDOC in forum John Deere Forum
    Last Post: 09-25-2012, 07:19 PM
  2. john deere d170
    By swalt in forum John Deere Forum
    Last Post: 07-26-2012, 04:00 PM
  3. Attachments John Deere D170 bumper vs. JD X320 bumper
    By dougb in forum John Deere Forum
    Last Post: 07-20-2012, 12:14 PM
  4. Hunting the right lawnmower..John Deere LTR 180 vs John Deere LX178 vs John Deere 332
    By janbhauge in forum Mower & Equipment Buying & Pricing
    Last Post: 05-24-2012, 08:51 AM
  5. John Deere fuel filter issue
    By Coxster in forum Small Engine & Mower Repair
    Last Post: 04-12-2012, 03:10 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
