Results 1 to 9 of 9
  1. #1
    Join Date
    Nov 2012
    Posts
    27
    Location
    Michigan
    Mower
    motor blowing white smoke-HELP!!!
    My old motor died so I got a used 17hp Briggs and put it on my tractor, I got it wired and it fired right up but after running for a few mins. it started blowing out white smoke and died, it started back up but then started blowing smoke again........what should I check on the motor? It was dark out when I got it running and pulled it into the backyard so I haven't had a chance to get a good look at the motor to see if there is anything visable as to why it started smoking, I just parked it and came in. I did have to swap out the carb from my old 13hp motor because the one on the 17hp motor was flooding out the engine. The motor in it now is a Briggs 310707 0137 E1....I did get the motor for free from someone that said it was good, it had been sitting for a long time and not ran. Any help would be appreciated.
  2.
  3. #2
    5,000 Post Club
    lawn mower fanatic's Avatar
    Join Date
    Jun 2012
    Posts
    6,759
    Location
    Pennsylvania
    Mower
    Two Honda HRX217HYA's and an HRR216TDA
    Re: motor blowing white smoke-HELP!!!
    Quote Originally Posted by bkm48198 View Post
    White smoke usually is caused by water or moisture where it shouldn't be. Here is a thread that might help you:
    http://www.lawnmowerforum.com/exmark...rf-tracer.html
    2013 4x6 custom utility trailer
    Honda HRX217(3)HYA mower
    Honda HRX217(5)HYA mower
    Honda HRR216TDA mower
    Echo SRM-225 trimmer
    Echo GT-2100 trimmer
    Echo PB-770T backpack blower
    Echo PB-255LN handheld blower
    Echo PE-225 edger
    Craftsman 24" 179cc dual-stage snow blower
    Black and Decker 22" electric hedge trimmer
  4. #3
    Join Date
    Nov 2012
    Posts
    27
    Location
    Michigan
    Mower
    The gas was fine a week ago when the other motor died, it ran good till it started blowing oil out the block and it never smoked at all, it just quit running. The new motor ran fine till it warmed up then started smoking, just wondering if valves might need adjusting or something like that, could a breather tube be clogged or fuel pump be a problem? I don't know much about small engines, car engines I know, lawnmowers are not something I have dealt with much.
  5. #4
    Join Date
    Nov 2012
    Posts
    27
    Location
    Michigan
    Mower
    I just read another thread that says it could be from fuel in the oil, I know the old carb was pouring gas into the cyld. and causing it to flood out and fill the motor so the spark plug had to be removed to blow fuel out of the motor. I'll try changing the oil tomorrow and see if that helps.
  6. #5
    slammed's Avatar
    Join Date
    Sep 2012
    Posts
    309
    Location
    Pisgah Forest
    Mower
    Ventrac 4231TD
    Let us know what you find.
  7. #6
    Join Date
    Nov 2012
    Posts
    27
    Location
    Michigan
    Mower
    After changing the oil and cleaning the plug it started up and blew out a lot of smoke, as it heated up the smoke got to be less and less until it quit smoking. I ran it for about 45 mins. picking up leaves and it seemed to be fine. I shut it off and restarted it a few mins. later with no smoke and running fine. The carb could use some fine tuning since it was taken off a smaller motor but it was running good, actually ran better under a load than it did without the blades spinning.
  8. #7
    Join Date
    Nov 2012
    Posts
    27
    Location
    Michigan
    Mower
  9. #8
    5,000 Post Club
    Join Date
    Jun 2012
    Posts
    6,759
    Location
    Pennsylvania
    Mower
    I'm glad it's back and running!
    Echo PE-225 edger
  10. #9
    Join Date
    Aug 2012
    Posts
    824
    Location
    California
    Mower
    TMW REPAIR & THE MUSICIANS WORKSHOP RECORDING STUDIO
    After you changed the oil and fired it up, that smoke you saw was no doubt oil that was deposited in your muffler before the oil change.
Similar Threads
  1. White smoke on a turf tracer.
    By F.Clayton in forum Exmark Forum
    Last Post: 08-10-2012, 03:51 AM
  2. white smoke
    By rushingt326 in forum Small Engine & Mower Repair
    Last Post: 04-27-2012, 02:21 PM
  3. White smoke....
    By rowdy in forum Small Engine & Mower Repair
    Last Post: 12-21-2011, 10:48 AM
  4. Engine Exhaust blowing white smoke and oil.
    By Jeffvador in forum Troy-Bilt Forum
    Last Post: 12-18-2011, 07:05 PM
  5. What does white smoke mean?
    By Tillie in forum Small Engine & Mower Repair
    Last Post: 09-30-2011, 11:07 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
