Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Blowing Fuses
  1. #1
    Join Date
    Jul 2011
    Posts
    37
    Location
    North Carolina
    Mower
    MTD - Yard Machines
    Blowing Fuses
    I have a Sears 917.254850 that keeps blowing fuses. Here is what I have done so far. Removed the plug at the alternator and still blew the fuse. Removed the wiring harness and inspected all wires. Found none melted or fused together. Replaced the terminal at the starter solenoid. Replaced the solenoid. Replaced the ignition switch. What am I overlooking? Could one of the safety switches be cousing this?
  2.
  3. #2
    reynoldston's Avatar
    Join Date
    May 2011
    Posts
    5,595
    Location
    Marion,NY
    Mower
    Ferris, John Deere, Wheel Horse, Toro,
    Re: Blowing Fuses
    Looks like a lot of unnessary work to me. Start from the blowen fuse and see what coler wire is causeing the short and work back from there. Should be very easy to find.
  4. #3
    Join Date
    Mar 2012
    Posts
    7,089
    Location
    Wisconsin
    Mower
    Toro
    Re: Blowing Fuses
    Go to Sears Parts Direct, you can download a owners manual which has a good wiring diagram to help you.
  5. #4
    Join Date
    May 2011
    Posts
    5,595
    Location
    Marion,NY
    Mower
    Re: Blowing Fuses
    Quote Originally Posted by Rivets View Post
    That will even make the job easier. Don't always have one but a good wiring diagram sure helps.
  6. #5
    Join Date
    Jul 2011
    Posts
    37
    Location
    North Carolina
    Mower
    MTD - Yard Machines
    Re: Blowing Fuses
    Quote Originally Posted by reynoldston View Post
    It is the Red wire from the hot side of the soleniod that goes and gives power to the ignition switch.
  7. #6
    Join Date
    Jul 2011
    Posts
    37
    Location
    North Carolina
    Mower
    MTD - Yard Machines
    Re: Blowing Fuses
    Thanks, but I have one already. I think I will use it to bypass and wire it like a tractor without all the safety switches.
  8. #7
    1,000 Post Club
    EngineMan's Avatar
    Join Date
    Jun 2012
    Posts
    1,813
    Location
    South Wales UK
    Mower
    No mowers
    Re: Blowing Fuses
    Quote Originally Posted by wcpost View Post
    I wouldn't bypass anything, check the ignition switch and then the diode, that's in the Red wire to the alternator.
    "Information/Knowledge not shared will be lost for ever, I will give freely any information that will help you out, you don't have to take it, that is up to you...! and the word "thank you" will not cost you anything, so be nice sometimes and use it"
  9. #8
    Join Date
    Mar 2012
    Posts
    7,089
    Location
    Wisconsin
    Mower
    Toro
    Re: Blowing Fuses
    I shouldn't have to say this, but make sure you check the diode in both directions.
  10. #9
    Join Date
    May 2011
    Posts
    5,595
    Location
    Marion,NY
    Mower
    Re: Blowing Fuses
    I had a repair job this pass summer with the same problim and the alterator was burned up. Might want to pull the flywheel and check it ?
  11. #10
    1,000 Post Club
    EngineMan's Avatar
    Join Date
    Jun 2012
    Posts
    1,813
    Location
    South Wales UK
    Mower
    No mowers
    Re: Blowing Fuses
    You don't need to pull the flywheel to check alternator, it can to done in situ..!
Similar Threads
  1. Blowing fuses
    By Willieksc in forum Craftsman Forum
    Last Post: 04-22-2014, 11:33 PM
  2. My Ferris IS1500 is blowing fuses.
    By 1954Terry in forum Small Engine & Mower Repair
    Last Post: 08-31-2012, 02:39 PM
  3. fuses keep blowing
    By jbadams in forum Small Engine & Mower Repair
    Last Post: 05-12-2012, 12:14 PM
  4. Cub Cadet blowing fuses
    By bwestbrook in forum Small Engine & Mower Repair
    Last Post: 03-28-2012, 10:42 PM
  5. Blowing fuses
    By Willieksc in forum Small Engine & Mower Repair
    Last Post: 08-25-2011, 08:07 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
