Results 1 to 4 of 4
  1. #1
    Join Date
    Sep 2010
    Posts
    62
    Location
    Tennessee
    Mower
    Thatch Attachment
    I'm kind of new to the riding mower scene. Just moved to the Mid-South and I've got a lot of grass with a big thatch problem. Rather than rent an aerator, are there such things as mower add-ons that I could invest in??
  2.
  3. #2
    173abn's Avatar
    Join Date
    May 2010
    Posts
    859
    Location
    JF county,Kansas
    Mower
    JD111,CF GT18,928d grasshopper
    Re: Thatch Attachment
    MeanMachine, the answer is yes.But what kinds of options depends on what type mower you have.Grasshopper.Zipper,eXmark,LandPride,DixiChopp er,JohnDeer all have options and many others that I haven't mentioned. russ
  4. #3
    Join Date
    Sep 2010
    Posts
    19
    Location
    Peterborough, Canada
    Mower
    Toro
    I found a great website called confessions of a lawn de-thatcher.
    I always love a bit of laughter with my info. He explains what causes thatch too. Which I think you should look into so that once you get rid of your thatch, you don't just get more.
    According to this gentleman, if you have warn climate grass. which your location makes me think you have, you need to de-thatch in the spring and if you have cool climate grass you need to de-thatch in the fall. The type of grass you have is also very important. He talks about something called Zoysai grass and St. Augustine grass which are very prone to heavy thatch. Just a few small items to consider.
  5. #4
    grnspot110's Avatar
    Join Date
    May 2010
    Posts
    276
    Location
    Missouri
    Mower
    This is what I use with my JD 1971-110, same unit fits many models w/proper mounting brackets. There are also tow behind models from Brinly (available from the "box Stores"), not as convenient, but will work. Same as with aerators, tow behinds will work, but won't do the job of commercial units. ~~ grnspot110
    Attached Images Attached Images
Similar Threads
  1. snow blower attachment fo JD LT 160
    By maildaddy1 in forum Snow Removal
    Last Post: 12-12-2014, 01:06 AM
  2. When to De thatch? +mulching
    By Hitch_Itch in forum Lawn Care & Landscaping
    Last Post: 05-28-2010, 11:46 PM
  3. Universal Sprayer Mount Attachment for Riding Mowers
    By MowerCaddy in forum Mower & Equipment Operation
    Last Post: 05-14-2010, 06:28 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
