Results 1 to 4 of 4
  1. #1
    Join Date
    Sep 2012
    Posts
    Location
    South Carolina
    Mower
    Murray
    Murray blade brake problems
    Hi I have a murray 40" cut, 13.5 HP, model # 405000X8. I removed the deck, replaced the belt, and reinstalled the deck. When I started the mower i saw white smoke from the deck and smelt burnt rubber. I thought I was burning up my belt but after further investigation i realized that the smoke was coming from the blade brake. When I engage the deck the brake stays on the pulley and causes it to smoke. How do i fix this? Can I adjust the idler pulley so that when i engage the deck the brake releases the mandrel pulley?
  2.
  3. #2
    Carscw's Avatar
    Join Date
    Aug 2011
    Posts
    6,375
    Location
    Georgia
    Mower
    Toro
    I would take the deck back off look and make sure no springs came off or the end of the brake lever bent and not sitting in the grove
    Sent from my iPhone using LMF
  4. #3
    Join Date
    Sep 2012
    Posts
    Location
    South Carolina
    Mower
    Murray
    Re: Murray blade brake problems
    It looks like all the springs are there. I can move the brake with my hand. When I engage the deck the piece touches the brake lever but not enough to move it. If I could get to move about 1 inch then the brake would move. When i lower the deck and take the belt off, everything works fine. Do you think the belt is too tight? If so how do I adjust the mower drive belt.
  5. #4
    Carscw's Avatar
    Join Date
    Aug 2011
    Posts
    6,375
    Location
    Georgia
    Mower
    Toro
    Sounds to me the belt is to short. I have done this put a shorter belt on so it would not slip in thick grass. Did you get the exact replacement belt or just try and match one to the old one.
Similar Threads
  1. Blade Brake Clutch Muffler 1984
    By Sohandy in forum Lawn Boy Forum
    Last Post: 05-07-2012, 10:09 PM
  2. Murray Blade Problem
    By 01z71 in forum Murray Forum
    Last Post: 04-04-2012, 03:56 AM
  3. Toro Model 20107 Blade/Brake Clutch Assy
    By AustinMike in forum Toro/Wheelhorse Forum
    Last Post: 07-25-2011, 11:02 AM
  4. Repairs Model 20107 Blade/Brake Clutch Assy
    Last Post: 06-30-2011, 01:22 PM
  5. Murray 36511x18 blade belt replacement
    By Manner11 in forum Murray Forum
    Last Post: 06-22-2011, 02:00 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
