Results 1 to 2 of 2
Thread: Zero turn hydraulic pump
09-07-2012, 12:49 PM #1
- Join Date
- Sep 2012
- Posts
- 1
- Location
- North Carolina
- Mower
- tank zero turn
Thanks for being here to ask questions!
I have a cub cadet commercial tank zero turn (model 53BB5DAV750) with 306 hours on it. It was working fine and i decided to serviced it with new belts, blades, etc. and change the hydraulic oil. After completeing the service the mower ran fine for approx 1 hr and then the left wheel stopped pulling. I am puzzled why the wheel stopped pulling since the mower has been maintained well, this being the second time changing the hydraulic oil and the manufacturer recommends changing in 500 hrs. Could i have trapped some air in the line? I was careful in trying to fill the filter with oil before installing during the service. What do you recommend or suggest?
Thank you!
J Warren
Advertisement
09-07-2012, 02:10 PM #2
- Join Date
- Aug 2012
- Posts
- 824
- Location
- California
- Mower
- TMW REPAIR & THE MUSICIANS WORKSHOP RECORDING STUDIO
Re: Zero turn hydraulic pump
I'm not familiar with your machine, but if it operated fine for an hour, surely all the air has been purged from the system. Do you have one or two hydro pumps?
Similar Threads
Hydraulic pump diagram
By ash3001 in forum Small Engine & Mower RepairReplies: 0Last Post: 07-02-2012, 02:50 PM -
Rebuilding z turn hydro gear pump
By jeffnang in forum Mower & Equipment OperationReplies: 1Last Post: 04-23-2012, 06:44 PM -
snapper hydraulic pump
By justinmills54 in forum Small Engine & Mower RepairReplies: 1Last Post: 04-17-2012, 06:33 PM -
Switching engines; kohler 15s w/sep fuel pump to kohler w/cab pump
By kchris2 in forum Kohler Engine ForumReplies: 16Last Post: 12-22-2011, 03:18 PM -
Toro/Kohler Zero Turn turn, left in rain 2 days, won't start/turn over/battery ok
By reflex439 in forum Kohler Engine ForumReplies: 5Last Post: 10-10-2011, 09:14 PM
