Results 1 to 9 of 9
  1. #1
    Join Date
    Jul 2010
    Posts
    55
    Location
    Arizona
    Mower
    MTD - Yard-Man
    Blade keeps coming off
    I recently got the blade stuck in a tree stump, the grass was kind of tall and I didn't see it. The engine stopped when it got stuck and I had to pull the blade out of the tree stump. After pulling it out the blade was loose and as I pulled the starter to start the engine the blade fell off after 2-3 pulls. Now every time I put the blade back on I tighten it as much as I can, its pretty tight. But when I try to start the engine, 2 - 3 pulls of the string and the blade falls off again.
    I don't know what to do, I keep putting the blade back on but it falls off and the engine doesn't start because of that (I think its a safety feature).
    Do you think there's something causing the blade to come loose really easily even after I tighten it on?
  2.
  3. #2
    briggs's Avatar
    Join Date
    Sep 2010
    Posts
    720
    Location
    Kingston ontario canada
    Mower
    murray,jhon deere honda,mastercraft ,MTD junk and many more
    Re: Blade keeps coming off
    what type of mower is it ..Is the crank shaft bent that happens sometimes when you hit something ...I would look closely where the blade mounts some have little pins that shear off once you hit something That hold the blade center ..When you tighten the blade you have to come on to it pretty good ..I lock the blade with a peace of 4x4 ..I put block against the housing of the mower and use it to hold the blade while i tighten it down (just be-careful please and i would by a new blade and lock for it just to be safe ...
    when all else fails ..Hit it with a hammer
    (I am here to help out where i can ..I will not be little u for asking a Question there is no such thing as a stupid question )
  4. #3
    1,000 Post Club
    RobertBrown's Avatar
    Join Date
    Aug 2010
    Posts
    1,278
    Location
    Florida
    Mower
    Ford
    Wink Re: Blade keeps coming off
    I'm assuming you are talking about a push mower and it's the MTD Yardman your profile refers too:
    Sounds to me like you may have sheared the key stock. It's meant to shear when you hit something to prevent serious damage. If the key is broke you won't be able to tighten the blade properly. It's either that or when the blade fell off you lost some parts, might want to go back to the stump with a magnet and see what you can excavate.
    I have an MTD and I've broke mine several times. I keep spares around so I can get it fixed quickly.
    If yours is like mine the blade bolts to a cast iron piece that attaches to the crankshaft. The key slides into a groove between these 2 parts.
    Disassemble the blade assembly to the crank and see if this is not the case. Be sure and remove the plug wire and remember if you turn the mower over it going to leak gas and oil if you don't drain it. This is a good time to change the oil since you're going to be under there anyway.
    If the key is sheared you should be able to get one from any briggs dealer or online but your done until you have a new one. Might want to get a few (thier cheap) in case that stump jumps out in front of your mower again
  5. #4
    Join Date
    May 2010
    Posts
    5,447
    Location
    Kansas, Butler county, Just east of DooDah
    Mower
    CTL
    If the crank is not bent also check the aluminum key on top of the engine... they will shear completely, or only partially causing, no start or timing being way off... Abrupt stops like you describe is exactly what shears the soft key in the flywheel... KennyV
  6. #5
    briggs's Avatar
    Join Date
    Sep 2010
    Posts
    720
    Location
    Mower
    Quote Originally Posted by KennyV View Post
    Yes i do agree there lol T.C s are good for that ...
  7. #6
    Join Date
    May 2010
    Posts
    66
    Location
    New Hampshire
    Mower
    Cub Cadet 3204
    Quote Originally Posted by stanley View Post
    The blade of what, an axe? Sorry to be sarcastic, but why don't you tell us what kind of mower you have? I sounds like the blade is spinning on the blade adapter, which could mean that the adapter is damaged. When you say the blade is pretty tight, what do you mean. The bolt should be VERY tight, with no chance that the blade can slip against the adapter. An impact wrench is a great idea,
    Yes, most push mowers require the blade to be attached in order to start as the blade functions as a flywheel for the motor. Some high-end mowers allow the mower to run without the blade.
  8. #7
    Join Date
    Sep 2010
    Posts
    13
    Location
    Mower
    I Don't Own a Mower :(
    I was going to say there maybe a problem with the key, if it has sheared then there is nothing to prevent the blade from falling off, it shouldn't be too expensive to fix.
  9. #8
    Join Date
    Sep 2010
    Posts
    62
    Location
    Tennessee
    Mower
    My first question was "What brand and model is your machine?" It sounds like a very simple and inexpensive repair job. Once you know the part that has been damaged, you can probably do the the work yourself.
  10. #9
    Join Date
    Sep 2010
    Posts
    19
    Location
    Florida
    Mower
    Poulan
    I think the fixture (or housing) that holds the blade in place has become cracked or broken. In all liklihood, you'll have to take the mower to a professional shop to have it evaluated and fixed.
Similar Threads
  1. How to remove rusty blade bolt?
    By rekees in forum Small Engine & Mower Repair
    Last Post: 07-29-2013, 06:03 AM
  2. Is it hard to resharpen a blade yourself?
    By Bethieboo in forum Small Engine & Mower Repair
    Last Post: 10-25-2010, 08:50 PM
  3. blade guide
    By jd335 in forum Small Engine & Mower Repair
    Last Post: 07-17-2010, 10:51 PM
  4. Intermittent Blade Clutch
    By lmf in forum Site Discussion
    Last Post: 06-17-2010, 08:52 PM
  5. Intermittent Blade Clutch
    By lmf in forum Small Engine & Mower Repair
    Last Post: 06-17-2010, 09:43 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
