Hello,
I just bought a SR1433. The guy that sold it to me put a little gas in, started it, drove it and cut a patch of grass. I bought the mower, brought it home and filled the tank and the problems started.
The gas just started leaking everywhere. The fuel lines are cracked and leaking and the air filter became soak and the black plastic below the filter filled up with a puddle full of gas.
Also, I tried starting it but the battery was to run down and wouldn't crank. I tried pulling the recoil but now the engine seems locked. I called the guy and he said the battery was to low on power to bring back down the drive gear on the start. Does this make sense?
So, I pulled the carb off, no gasket between the carb and motor, does it need one? I soaked it overnight in Gunk carb dip and it at least looks cleaner.
I'm off to a snapper dealer for some new fuel line and maybe a carb kit and air cleaner.
Any other advise is helping me get this mower running would be great.
