Results 1 to 4 of 4
  1. #1
    Join Date
    Jul 2012
    Posts
    Location
    Georgia
    Mower
    SR1433 new owner, needs carb help, starter help
    Hello,
    I just bought a SR1433. The guy that sold it to me put a little gas in, started it, drove it and cut a patch of grass. I bought the mower, brought it home and filled the tank and the problems started.
    The gas just started leaking everywhere. The fuel lines are cracked and leaking and the air filter became soak and the black plastic below the filter filled up with a puddle full of gas.
    Also, I tried starting it but the battery was to run down and wouldn't crank. I tried pulling the recoil but now the engine seems locked. I called the guy and he said the battery was to low on power to bring back down the drive gear on the start. Does this make sense?
    So, I pulled the carb off, no gasket between the carb and motor, does it need one? I soaked it overnight in Gunk carb dip and it at least looks cleaner.
    I'm off to a snapper dealer for some new fuel line and maybe a carb kit and air cleaner.
    Any other advise is helping me get this mower running would be great.
  2.
  3. #2
    1,000 Post Club
    EngineMan's Avatar
    Join Date
    Jun 2012
    Posts
    2,007
    Location
    South Wales UK
    Mower
    No mowers
    Re: SR1433 new owner, needs carb help, starter help
    36352 1 * Carburetor To Intake Pipe Gasket
    36942 1 * Intake Pipe Gasket
    36358 1 * Air Cleaner Gasket
    Try and start it with a good battery
    Attached Images Attached Images
    "Information/Knowledge not shared will be lost for ever, I will give freely any information that will help you out, you don't have to take it, that is up to you...! and the word "thank you" will not cost you anything, so be nice sometimes and use it"
  4. #3
    Join Date
    Feb 2012
    Posts
    28
    Location
    Ohio
    Mower
    the carb prob needs redone look at the float if it has a hole in it it will fill the intake with gas i had a similar prob with mine it could just be junk in the carb pull the spark plug out and turn the motor over it will remove the the gas from the cyl
  5. #4
    Join Date
    Jul 2012
    Posts
    Location
    Georgia
    Mower
    I rebuilt the carb, changed the air filter, new fuel lines, fuel filter and inline fuel shut off, charged the battery, greased what fittings I could find, put 00 grease in the rear end and changed the oil and filter.
    The cylinder was full of gas which is why it wouldn't turn over, the oil had so much gas it poured out like water, the air filter was shot.
    I got it started and went out to cut the lawn and so far so good. I wish it had a higher cut height. Has anyone taken a link out of the adjusting chains? Also, any place good for prices on tires and muffler?
    Thanks for your advice. Sorry i didn't take pictures, normally I do. Today was just a bear in the heat, I just wanted to get this thing done.
Similar Threads
  1. White Smoke Coming Out of Exhaust and Carb-Carb gets full of oil
    By maxcalvada in forum Small Engine & Mower Repair
    Last Post: 06-06-2015, 07:10 PM
  2. Snapper SR1433
    By eaglesrule in forum Small Engine & Mower Repair
    Last Post: 07-21-2012, 11:39 AM
  3. starter, how to reverse direction on a craftsman lawn mower starter
    By gemayna in forum Small Engine & Mower Repair
    Last Post: 04-19-2012, 06:45 PM
  4. My new Snapper SR1433
    By twall in forum Snapper Forum
    Last Post: 09-30-2011, 07:46 AM
  5. Snapper SR1433
    By SuthernBowRush in forum Snapper Forum
    Last Post: 07-11-2011, 09:15 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
