Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Join Date
    Apr 2012
    Posts
    5
    Location
    Michigan
    Mower
    John deere 425 hard start
    My JD 425 has Kawasaki FD620D V twin gas engine. 1464 hours and recently became hard to start.
    Cranks and cranks, sputters and back fires and will not start. Plugs are wet, put in dry plugs and may start then.
    Replaced electric fuel pump. No change. Dealer suggested ignition delay module, no change.
    Removed carb, cleaned and replaced needle valve and fuel shut off solenoid (tested bad)
    When cranking without air cleaner see raw fuel pulsing out of carb, back fires, sputters, plugs get wet and no start.
    It does not use oil, no other problems. If can get started, will run fine to mow, etc. and will easily re-start when warm. Let sit and she gets real stubborn.
    I am at wits end on this - the carb looks so simple (?) but seems to be flooding the engine.
    Any thoughts on this - if no help will have to take to dealer as not sure what to do next.
    Thanks for the suggestions
  2.
  3. #2
    Join Date
    Apr 2012
    Posts
    5
    Location
    Michigan
    Mower
    Re: John deere 425 hard start
    I finally got if fixed. The fule shut off module in the bottom of the carb tested bad and was allowing fuel to leak into the manifold. I replaced the needle valve under the float and once correctly adjusted all is fine. Due to lack of rain it has been sitting for about 2 weeks and last night I thought I'd see how it started and was fine. It fired right up, ran fine at full throtle.
  4. #3
    Join Date
    Jan 2013
    Posts
    Location
    Texas
    Mower
    Sounds like what is happening to mine. 9 months old and 32 hrs on meter. Wont start to point of draining battery. Once started, runs good. Will re start warm but not cold or if has been sitting a few days or more.
  5. #4
    Join Date
    Apr 2012
    Posts
    5
    Location
    Michigan
    Mower
    It now seems that I only thought that I had it fixed. Was starting better this fall/winter and now has reverted to its old evil ways.
    I am back to crank, crank, sputter, sputter, backfire and all. Have to keep grinding starter until it catches and runs, really rough at first then smooths out.
    Once warm barely need to touch the key and it is going. Seems to run strong and smooth once warm, no smoke, no sputter.
    I think that the next stop will be the dealer as have been through the carb/fuel system and have no idea what to do next.
  6. #5
    Join Date
    Mar 2012
    Posts
    7,092
    Location
    Wisconsin
    Mower
    Toro
    I would check the valve, both clearance and if they are sealing properly.
  7. #6
    Join Date
    Apr 2012
    Posts
    5
    Location
    Michigan
    Mower
    Yeah - I have been thinking about the valves because of the popping/bakfiring. Have already checked valve tappett clearance and is OK.
    Guess that I better do a compression check and/or pull the heads.
    Thanks for the suggestion - steers my thinking away from the fuel system.
  8. #7
    Join Date
    Mar 2012
    Posts
    7,092
    Location
    Wisconsin
    Mower
    Toro
    If you're able to do so, I would do a cylinder leak down test. It will give you a better idea it the valves are the problem.
  9. #8
    Join Date
    Jul 2011
    Posts
    96
    Location
    Georgia
    Mower
    Walker MTGHS,Ferris 52", Deere 21"
    I have a PDF of the tech manual if needed, shoot me your email if you want it
    Joe
  10. #9
    PJ's Avatar
    Join Date
    Mar 2012
    Posts
    176
    Location
    South Africa
    Mower
    Quote Originally Posted by cfwetzler View Post
    To me it sounds like timing did you have a suden stop by any chance? Could be a key that was shared causing the misfiring
    PJ
  11. #10
    Join Date
    Aug 2010
    Posts
    47
    Location
    Kansas
    Mower
    F725, LX 178,420, 445, 285, SX75, Honda H1011, Hustler Fastrak, John Deere JX75, Honda HRR216VXA
    I'd recheck that fuel shut-off module again. It kind of sounds like you might be getting dirt in the carb somehow.
Similar Threads
  1. 425 John Deere starting problems
    By sbv5988 in forum John Deere Forum
    Last Post: 07-06-2012, 01:41 PM
  2. John Deere 425 Engine Problem
    By Farmboy in forum Small Engine & Mower Repair
    Last Post: 07-05-2012, 10:12 PM
  3. John Deere 14 SE hard starting
    By s10sleeper in forum Small Engine & Mower Repair
    Last Post: 05-01-2012, 12:04 AM
  4. john deere 425 manual
    By deere7 in forum Small Engine & Mower Repair
    Last Post: 04-30-2012, 06:49 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
