Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2012
    Posts
    Location
    North Carolina
    Mower
    Gravely
    kohler cv20 carb not getting fuel.
    MOWER JUST DIED. AND WOULD NOT CRANK AGAIN. IF YOU PUT STARTING FLUID IN CARB IT WILL CRANK BUT NOT STAY PAST THAT.
    I EMPTIED GAS TANKS AND CLEANED OUT. ONE TUBE INSIDE WAS BROKEN. SO FIX THAT.REPLACED FUEL LINES, FUEL FILTER, FUEL PUMP. FUEL NOT EVENING MAKING TO FUEL FILTER. WHAT MIGHT BE CAUSING THIS?
  2.
  3. #2
    1,000 Post Club
    EngineMan's Avatar
    Join Date
    Jun 2012
    Posts
    2,005
    Location
    South Wales UK
    Mower
    No mowers
    Re: kohler cv20 carb not getting fuel.
    Blow up the pipe to the tank, and see if you get fuel. with the cap off.
    as to be a blockage something blocking the passage of fuel.
    When you do get fuel, clean out the carb.
    "Information/Knowledge not shared will be lost for ever, I will give freely any information that will help you out, you don't have to take it, that is up to you...! and the word "thank you" will not cost you anything, so be nice sometimes and use it"
  4. #3
    Join Date
    Jun 2012
    Posts
    Location
    North Carolina
    Mower
    Gravely
    Quote Originally Posted by EngineMan View Post
    Blow up the pipe from the tank, and see if you get fuel. with the cap off.
    I WILL TRY THIS. THANKS FOR THE HELP.
Similar Threads
  1. 8hp Briggs updraft carb leaking fuel while trying to start.
    By mrfixit in forum Briggs & Stratton Forum
    Last Post: 10-27-2012, 09:36 AM
  2. Kohler Carb. Problem
    By swo in forum Kohler Engine Forum
    Last Post: 03-31-2012, 03:27 PM
  3. Replies: 2
    Last Post: 03-18-2012, 07:43 PM
  4. Replies: 16
    Last Post: 12-22-2011, 03:18 PM
  5. no fuel @ carb
    By lifttruck6 in forum Small Engine & Mower Repair
    Last Post: 06-28-2011, 07:52 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
