Results 1 to 2 of 2
Thread: Cub Cadet 1450
  1. #1
    Join Date
    Jun 2012
    Cub Cadet 1450
    hello all, just picked up a cadet 1450 hydro not sure of year may be early 70's with 14hp kohler k321 shes been sitting for a while carb looks worn no starter on motor so part of flywheel as been exposed to weather for years. gas tank removed. Wondering whats the first step i should take? thinking of getting a used starter and see if she turns over however i dont want to be out $60 for nothing. Perhaps ill pull the 321 and inspect it i understand its a proven engine. Will try and post some pics soon of the project. - Nick
  3. #2
    Join Date
    May 2010
    Kansas, Butler county, Just east of DooDah
    Re: Cub Cadet 1450
    Hello Nick .... The 1450 is a GREAT garden tractor ... I have one that I have Used/Abused since the mid 1970's when it was New.
    It has thousands of hours on it and still starts & runs easily... I have not changed the points OR spark plug in Decades.... It runs perfectly on today's gasoline, and will fire up and run on the fuel left over from the prior year. I have Never had any problem with that little tractor. Just used the 44 inch deck a couple days ago, great mower.
    That is one of Kohler's best engines... their only short coming is from owners that did Not drain and replace the oil every year.... VERY good hydrostat trans run IH HiTran or it's equivalent... change the fluid and filter every few years... KennyV
Similar Threads
  1. cub cadet rtz 50
    By Charles Arp in forum Small Engine & Mower Repair
    Last Post: 04-30-2012, 08:28 PM
  2. cub cadet bagger
    By sharp4716 in forum Small Engine & Mower Repair
    Last Post: 04-26-2012, 07:07 PM
  3. cub cadet
    By quads in forum Cub Cadet Forum
    Last Post: 12-19-2011, 03:02 PM
  4. Cub cadet
    By DonBrasco in forum Cub Cadet Forum
    Last Post: 06-02-2011, 07:31 AM
  5. Cub Cadet?
    By Ken Fountain in forum Cub Cadet Forum
    Last Post: 04-30-2011, 06:15 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
