Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2012
    Posts
    Location
    Michigan
    Mower
    Cub Cadet LT 1045 Will not start.
    I do not hear the click I usally get when I turn key. I have checked 20a fuse at hood brace OK. Tractor turns over but will not start.
  2.
  3. #2
    Join Date
    Dec 2010
    Posts
    21
    Location
    Oregon
    Mower
    Re: Cub Cadet LT 1045 Will not start.
    It sounds like your fuel solenoid (mounted on the bottom of the carburetor) is not working. Here is a link to all the literature available for the LT 1045 (Cub Cadet is an MTD brand):
    http://www.mtdproducts.com/webapp/wc...ter+Serial+%23
    If you scroll down the list, when you get to SERVICE MANUAL 07 - FUEL SHUT-OFF SOLENOID, click on PDF Version, and you can read about the fuel solenoid. I believe your tractor has a Kohler engine. Here's a link to Kohler's manuals and parts page: Kohler Engines: Owners and Service Manuals: Manuals and Maintenance
    You can download your engine's service manual, which will tell how to test and replace the solenoid. Good luck!
  4. #3
    Join Date
    Jun 2012
    Posts
    Location
    Michigan
    Mower
    I put a tester on lead to fuel selinoid valve.No power. There is only one fuse I can find its on the frame. It looks ok.
    I got it running. I think it was the Oil Sentry. I remove it and checked it's wire.After i cleaned it The gas shut off starteds to click again.
Similar Threads
  1. jump start cub cadet
    By Tadams32 in forum Small Engine & Mower Repair
    Last Post: 04-19-2012, 10:20 PM
  2. Cub Cadet LT-1045 Drive Belt Replacement
    By Richard Stone in forum Small Engine & Mower Repair
    Last Post: 04-07-2012, 08:13 PM
  3. Cub Cadet LTX 1045 will not move
    By Lee2012 in forum Small Engine & Mower Repair
    Last Post: 04-07-2012, 12:01 PM
  4. 2009 LT 1045 Cub Cadet
    By Bobberboy in forum Small Engine & Mower Repair
    Last Post: 09-10-2011, 11:17 AM
  5. Cub Cadet LTX 1045
    By chaddavidson in forum Cub Cadet Forum
    Last Post: 07-05-2011, 11:32 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
