harrym1byt
- Jun 15, 2012
- Threads
- 2
- 7
Not the exact model, but near enough - same colours and same controls as near as I can tell. It is located at the very rear of the garden and it is very, very wet out there. :laughing:
Here in the UK we have recently had a few quite wet summers, but none the less the grass still does need to be cut regularly. I wait as long as I can after rain to allow the grass to dry out, but still the plastic duct between the deck and the grass collector on the rear completely chokes up with the cut grass. It is so tightly packed, that it is a PITA to force a way through it and eventually clear it. It doesn't seem to make much difference whether the grass is long or short, whether I use the collector box or not - it sticks in the duct and chokes it up. Ignore it and it becomes so compacted that the grass springs back out and jams the cutting blade.
I've checked the fan air intake, which is all clear, cleaned out the duct thoroughly and pressure washed it all out numerous times. Other than that it works fine, when the grass has had several weeks to completely dry out, but that dry long enough weather just doesn't seem to happen, so I have to mow when I can.
We bought the ride on used, so we don't have a manual for it, but I cannot see any obvious way to close the duct and let it just cut the grass without it trying to flow down that duct and choking it.
I was thinking to add some sort of removable cover plate over the deck discharge slot, to prevent any grass entering the duct, but wondered if anyone might have already found a better solution?
