Hi. Just acquired a 68 and will not start. It's a pull start. There is no spark, fuel is being fed. Ignition coil or the neutral safety is the culprit. I'm gonna change both just to cover bases.
Question is, what is the second wire coming from underneath the coil then disappearing under the flywheel. One of the wires connects to one of the mounting bolts with an eyelet, the other one does the disappearing act. How would i go about swapping coils? I can cut and put a butt connector if necessary but don't want to do that. Please help.... thanks
