This forum
Equipment
Small Engine & Mower Repair
Kohler
Discuss Kohler engline repair in this forum.
Go to page
Go
Next
1 of 36
Go to page
Go
Next
Last
Locked
Sticky
Kohler Engines model and spec. number location
Scrubcadet10
Mar 11, 2022
Replies
Views
5K
Mar 11, 2022
Scrubcadet10
R
Kohler SV620 new solenoid, still no click.
robb123
49 minutes ago
Replies
Views
9
49 minutes ago
robb123
R
S
Open Positive? *Update*
sano888
Feb 3, 2024
Replies
28
Views
3K
Today at 7:41 AM
sano888
S
H
Kohler ECV870 misfiring
heavy_kevie
Tuesday at 11:40 PM
Replies
9
Views
252
Yesterday at 6:16 PM
VegetiveSteam
V
E
crank case loose
ed fender
Friday at 12:27 PM
Replies
13
Views
561
Yesterday at 6:08 PM
VegetiveSteam
V
B
Part number mystery!
Bearrepair
Apr 17, 2024
Replies
8
Views
376
Monday at 4:26 AM
I
B
Starter will not turn engine sometimes
Boyde
Apr 13, 2024
Replies
Views
901
Apr 17, 2024
I
M
Coil help
mudpie
Apr 16, 2024
Replies
Views
255
Apr 16, 2024
Kohler Courage no throttle adjustment
ryanbeymer
Apr 13, 2024
Replies
Views
262
Apr 13, 2024
Hammermechanicman
D
Husqvarna with KT725 suddenly started surging/pulsing/cycling
Doug Hoshelag
Apr 8, 2024
Replies
5
Views
400
Apr 9, 2024
R
Kohler Courage SV730s Engine Control Picture
ryanbeymer
Mar 24, 2024
Replies
11
Views
587
Apr 7, 2024
ryanbeymer
W
Engine swap and wiring help
Waynejd400
Apr 4, 2024
Replies
4
Views
467
Apr 6, 2024
R
Command 25CV Cylinder Wall Damage
Riddler
Feb 16, 2024
Replies
25
Views
2K
Apr 5, 2024
Riddler
R
J
CV461s 16 HP. New aftermarket carb, won't run correctly?
joea99
Nov 11, 2023
5
Replies
52
Views
5K
Apr 5, 2024
B
J
Kohler Xt675 carb leaking out of the throat
juntjoo
Mar 29, 2024
Replies
17
Views
787
Apr 5, 2024
B
Y
Ethanol only?
Yardman999
Mar 29, 2024
Replies
17
Views
695
Apr 2, 2024
7394
G
Kohler KT725 won't start!!!!!!
goosemasterkl
Mar 29, 2024
Replies
Views
346
Mar 29, 2024
goosemasterkl
G
B
K321 14 HP engine kick back when starting
BOBTHEBOPPER
Mar 25, 2024
Replies
8
Views
519
Mar 29, 2024
BOBTHEBOPPER
B
Does anyone know the difference between a k301 and a k321 Carburetor?
123tim
Mar 27, 2024
Replies
Views
318
Mar 28, 2024
B
Darn kohler courage engines are such crap
Craftsman Garage
Mar 24, 2024
Replies
8
Views
637
Mar 26, 2024
GearHead36
G
Add an impulse fuel pump to Kohler VS600?
HunterFarmer
Mar 19, 2024
Replies
5
Views
496
Mar 20, 2024
S
G
*%$#&^* Oil Filter
GearHead36
Feb 19, 2024
Replies
21
Views
2K
Mar 7, 2024
GearHead36
G
I
SV740 Starter
Replies
5
Views
532
Mar 7, 2024
Kohler SV735 DSAM Bad??
Turbodriven
Mar 4, 2024
Replies
16
Views
971
Mar 5, 2024
Turbodriven
Kohler 7000 series kt745 starts runs for a lil bit then dies but still has 13 volts but wont start just clicks...
mromley1
Feb 29, 2024
Replies
Views
560
Feb 29, 2024
L
Kohler SV840 no spark
LawnWizard
Feb 26, 2024
Replies
10
Views
931
Feb 27, 2024
LawnWizard
L
S
Kohler SV610-0020 speed controller assembly
Sbaker1991
Feb 26, 2024
Replies
Views
434
Feb 26, 2024
R
L
Kohler SV840 stalls when PTO engaged, but only when cold.
LawnWizard
Feb 25, 2024
Replies
Views
437
Feb 25, 2024
LawnWizard
L
D
hydro-lock in a Kohler
Danl99
Jan 10, 2024
Replies
37
Views
6K
Feb 25, 2024
Danl99
D
C
Governor surging carb.
captainkirk00
Feb 24, 2024
Replies
4
Views
593
Feb 25, 2024
efred
E
N
GT20A Command 20 Charging issue
NewHolland GT20A
Feb 23, 2024
Replies
Views
458
Feb 24, 2024
NewHolland GT20A
N
R
Short Block for CV25S Advice
Riddler
Feb 17, 2024
Replies
4
Views
484
Feb 20, 2024
F
Kohler CV491S Governor Problem
Freddie21
Feb 12, 2024
Replies
22
Views
2K
Feb 19, 2024
Freddie21
F
T
Kohler SH265 6.5 HP motor
tcnrepairs
Feb 17, 2024
Replies
Views
379
Feb 17, 2024
Cub Cadet with KT725 only runs well under load
Tillyton
Feb 16, 2024
Replies
Views
482
Feb 17, 2024
Tiger Small Engine
R
Riddler
Feb 17, 2024
Replies
Views
419
Feb 17, 2024
Riddler
R
U
Country Clipper Kohler engine identification.
user4579
Feb 3, 2024
Replies
23
Views
2K
Feb 13, 2024
Tiger Small Engine
T
Kt 745 starting problem.
Talltree
Feb 9, 2024
Replies
Views
743
Feb 10, 2024
T
Hard to start
tcnrepairs
Feb 9, 2024
Replies
Views
474
Feb 9, 2024
tcnrepairs
T
L
Need advice: Kohler sv840 no start
LawnWizard
Feb 7, 2024
Replies
5
Views
662
Feb 8, 2024
R
I
Kohler outsources energy division to Platinum equity
Replies
Views
640
Feb 6, 2024
7394
KT725 stupid question
Scrubcadet10
Feb 2, 2024
Replies
Views
621
Feb 4, 2024
shurguywutt
15HP Command (cv15s) Running Rich
Wazza65
Jan 24, 2024
Replies
Views
1K
Feb 2, 2024
Tiger Small Engine
J
How fast?
juntjoo
Jan 17, 2024
Replies
17
Views
2K
Jan 25, 2024
Freddie21
F
J
Why are both my aftermarket Kohler XT carbs leaking?
juntjoo
Jan 23, 2024
Replies
5
Views
784
Jan 24, 2024
Tiger Small Engine
H
Kohler head gaskets
hlw49
Jan 15, 2024
Replies
Views
3K
Jan 22, 2024
J
anyone familiar with this particular flywheel key?
juntjoo
Jan 1, 2024
Replies
28
Views
2K
Jan 12, 2024
juntjoo
J
Kohler engine no spark till coasting.
mcostello
Dec 30, 2023
5
Replies
61
Views
7K
Jan 9, 2024
TobyU
T
C
Scag scz61v-34kh hard to crank
crazy Greg
Dec 24, 2023
Replies
16
Views
1K
Jan 5, 2024
crazy Greg
C
CV491-27509
Scrubcadet10
Dec 21, 2023
Replies
10
Views
1K
Jan 2, 2024
Scrubcadet10
B
kohler ch25 voltage regulator
BRIAN10
Dec 30, 2023
Replies
Views
1K
Jan 2, 2024
VegetiveSteam
V
Go to page
Go
Next
1 of 36
Go to page
Go
Next
Last
You must log in or register to post here.
Equipment
